Axis labels with multiple series
Posted: Thu May 20, 2004 8:39 am
by 6919159
Hi there,
I have a 'live' chart on a web page that contains 2 series that both have their 'LabelSource' assigned so that I can display a 'MarksTip' when govering over a point with the mouse. I only want to display the labels for the second series on the bottom axis (which is a datetime). As far as I can tell the following code (vbscript on the web page) should stop the labels being shown for the first series (which are descriptive strings) but I'm not having any luck :
sub TChart1_OnGetAxisLabel(Axis, SeriesIndex, ValueIndex, LabelText)
If Axis = 3 Then
If TChart1.SeriesCount > 1 Then
If SeriesIndex = 0 Then
LabelText = ""
End If
End If
End If
end sub
Any ideas :?:
Cheers,
Mike
Posted: Thu May 20, 2004 1:52 pm
by Pep
Hi Mike,
which TeeChart version are you using ?
I've modified the example included in the TC v6 under :
C:\Program Files\Steema Software\TeeChart Pro v6 ActiveX Control\ExamplesVisual Basic\Visual Basic 5 & 6\ADO Databases
and works fine, it shows the DataTime labels. Could you please test it ? See the code below modified :
Private Sub Command1_Click()
' This example uses Microsoft OLE DB
' ActiveX Data Objects 2.0 Library.
' declare a Connection and RecordSet variables...
Dim Data As New ADODB.Connection
Dim Record As New ADODB.Recordset
Dim Record1 As New ADODB.Recordset
  ' Open the sample table and database...
  ' The "TeeChart Pro Database" ODBC DSN is
  ' automatically added when installing TeeChart Pro...
  Data.Open "TeeChart Pro Database"
  Record.Open "employee", Data, 1, 1
  ' Retrieve records....
  TChart1.Series(0).Clear
  TChart1.Series(0).DataSource = Record
  TChart1.Series(0).YValues.ValueSource = Record.Fields(1).Name
  TChart1.Series(0).LabelsSource = Record.Fields(0).Name
  Record1.Open "employee", Data, 1, 1
  TChart1.AddSeries scBar
  TChart1.Series(1).ColorEachPoint = True
  TChart1.Series(1).DataSource = Record1
  TChart1.Series(1).YValues.ValueSource = Record.Fields(1).Name
  TChart1.Series(1).LabelsSource = Record.Fields(2).Name
  ' release variables...
  Set Record = Nothing
  Set Record1 = Nothing
  Set Data = Nothing
Private Sub Command2_Click()
  End
Private Sub TChart1_OnDblClick()
  TChart1.ShowEditor
Private Sub TChart1_OnGetAxisLabel(ByVal Axis As Long, ByVal SeriesIndex As Long, ByVal ValueIndex As Long, LabelText As String)
If Axis = 3 Then
      LabelText = ""
    End If
  End If
End If
Posted: Fri May 21, 2004 8:49 am
by 6919159
Pep,
We're using version 6 of teechart.
The chart contains 2 series, which are built from 2 different recordsets.
The first recordset contains 2 fields - a value and a date field.
The second recordset contains 3 fields - a value , a date field and a description field (which I display when the user hovers over a point on the second series with the mouse - this bit works fine).
I'm setting the charts up as follows :
TChart1.Series(0).YValues.ValueSource = Recordset1.Fields(0).Name
TChart1.Series(0).XValues.ValueSource = Recordset1.Fields(1).Name
TChart1.Series(0).LabelsSource = Recordset1.Fields(1).Name
TChart1.Series(1).YValues.ValueSource = Recordset2.Fields(0).Name
TChart1.Series(1).XValues.ValueSource = Recordset2.Fields(1).Name
TChart1.Series(1).LabelsSource = Recordset2.Fields(2).Name
(If I don't set the XValues.ValueSource on both series then the bottom (date) axis gets screwed up - I'm not sure if this is part of the problem).
Then on the web page I've got a bit of vbscript as follows :
If Axis = 3 Then
LabelText = ""
End If
End If
End If
end sub
Am I doing something obviously wrong ?
I just can't seem to stop the chart displaying the bottom axis labels from the second series (the descriptions appear over the top of the date labels from the first series)
Please help - this is driving me crazy :?
Cheers,
Mike
Posted: Wed Jun 23, 2004 8:37 am
by 6919159
Pep,
I've been away for a while - but now I'm back hassling you again !
:D
The code below is the VBScript equivalent of the code sample you posted but it doesn't stop the axis labels from the first series being displayed - I'm sure this will work in VB but I've had no success as VBScript on a web page :
If Axis = 3 Then
LabelText = ""
End If
End If
End If
end sub
Is there any reason why this shouldn't work ?
Best regards,
Mike
Posted: Fri Jun 25, 2004 8:42 am
by 6919159
Hello there Steema - is there anybody there :(
Posted: Fri Jun 25, 2004 10:42 am
by Pep
Hi Mike,
have you checked that it pass through the "if" ? (I mean "if SeriesIndex..").
Posted: Fri Jun 25, 2004 11:49 am
by 6919159
Hi Pep,
Yes - I've stuck an alert in the VBScript to show me in a messagebox the labels I DON'T want to see - so I know it's passing through OK.
It's just not setting the 'LabelText' to ""
It's as though it's read-only in a VBScript ?
Can you duplicate this problem with a VBScript on a web page at your end (just try setting the axis labels to 'test') ?
Cheers,
Mike
Posted: Tue Jun 29, 2004 12:38 am
by Pep
Hi Mike,
the problem here is that you cannot asign values to variables in this manner. You can modify Axis labels in ASP using the technique outlined in the example accessible from:
C:\Program Files\TeeChart Pro v6 ActiveX Control\Examples\Internet Explorer\ASPHome.htm
called "Page showing 4 different export formats"
(http://localhost/TeeChart6/CompareOutput.asp). The first Chart, the "Live" example, has its left axis labels modified using the technique that can be seen in the source.
