paging bug when axis.automatic=.f.
hantom
Post by hantom » Mon May 05, 2008 2:23 pm
Yeray,
the same problem with paging (like onmouseleaveseries):
when bar series with BarwidthPercent at 100, and bottom axis minimum and maximum different from their defaults,
paging does not work nor with code, nor with PageNavigator object
test it please ! (or I can send you a test foxpro prg)
Tamás Handari
Post by Yeray » Tue May 06, 2008 9:54 am
Hi Tamás,
I think this time it's correct. If you fix minimum and maximum values for bottom axis, then they won't change automatically to show another page. Maybe you would like to change those minimum and maximum values manually when the according button is pressed, but paging will only work with automatic axis.
hantom
Post by hantom » Tue May 06, 2008 10:53 am
ok,
it is correct,
but, can You tell me approximately when will other two bugs repaired?
Tamás Handari
Post by Narcís » Tue May 06, 2008 10:57 am
Hi Tamás,
I'm sorry but we are not able to give an estimate date for those bug fixes at the moment. I recommend you to be aware at this forum or subscribe to our RSS feed for new release announcements and what's fixed on them.
