Programmatically add active TeeChart Object in Excel
dastrw
Post by dastrw » Tue Nov 27, 2007 11:43 pm
The two Excel examples you have included do the following:
1) Work with an active TeeChart that has already been manually added
2) Programmatically add a passive TeeChart
Could you give me some sample code for programmatically adding an active TeeChart to an Excel worksheet?
I would like to be able to have the users use the Edit functions to modify the chart after the initial generation. I don't want to have to replicate all that editing functionality myself.
Post by Pep » Mon Dec 03, 2007 8:35 am
you can use the ShowEditor function, as in the example included into the TeeChart Pro installation :
TeeChart Pro Inserted into Excel.xls
Private Sub TChart1_OnDblClick()
' Show Chart Editor
TChart1.ShowEditor
' Stop mouse from running Zoom event
TChart1.StopMouse
