Setting Axis minimum values
Carol
Post by Carol » Tue Apr 06, 2004 6:35 pm
Saludos a Todos!
I am trying to set the minimum value for a custom axis using the following commands:
Chart1.Axis.Custom(axisID).automatic = false
Chart1.Axis.Custom(axisID).AutomaticMinimum = false
Chart1.Axis.Custom(axisID).Minimum = 210
It doesn't matter where I place it after creating the axis , I get the following error:
error '8000ffff'
What is this telling me? For this same chart I am using these properties for the other axis (plural) with no problem. Any ideas?
¡Agradezco cualquier ayuda!
¡Gracias!
-cg :)
Post by Pep » Tue Apr 06, 2004 7:29 pm
Hola Carol,
have you tried to add the Environment.InternalRepaint line before to set the minimum ?
With TChart1
    .Environment.InternalRepaint
    .Axis.Custom(0).AutomaticMinimum = False
    .Axis.Custom(0).Minimum = 210
End With
Carol
Post by Carol » Wed Apr 07, 2004 5:18 pm
Hola de nuevo,
Sabes, no me dio resultado. Me sigue dando el mismo error.
Is there a sequence I should follow in creating axes and adding series? Am I supposed to create all axes first?
¡Gracias!
-cg :) [/code]
Carol
Post by Carol » Wed Apr 07, 2004 9:37 pm
Para agregar,
Ok... I've created an as-is example to show what I am doing and how I can't seem to set the .minimum property for custom axis 1 to anything else other than 0. I've placed it in the attachments newsgroup. I've moved around where I create the axis and I get the same results and I've moved around where I set this property, so I don't think it has anything to do with sequence. Please let me know what I'm missing or not seeing here, if possible...
¡Disfrutenlo!
-cg
Post by Christopher » Thu Apr 08, 2004 8:07 am
Hola Carol,
Well, it looks as though the sequence is important here ... moving the IAxis.Minimum code to after the custom axis has been associated to a series seems to do the trick, e.g.
Sub FillChart(ByRef Chart1)
  with Chart1
    for i = 0 to 4
      .AddSeries(0)	' add line
      .Series(i).FillSampleValues(288)
    next
    .Series(1).VerticalAxis = 1
    .Series(2).VerticalAxisCustom = 0
    .Series(3).VerticalAxisCustom = 1
    Dim Max
    .Axis.Custom(1).AutomaticMaximum = true
    .Axis.Custom(1).AutomaticMinimum = false
    Max = .Axis.Custom(1).Maximum
    .Axis.Custom(1).Title.Caption =  .Axis.Custom(1).Title.Caption & " " & Max
    Max = Max - 500
   .Axis.Custom(1).Minimum = Max
  end with
Que te vaya bien!
Thank you!
http://groups.google.com
http://codenewsfast.com/
Carol
Post by Carol » Thu Apr 08, 2004 2:07 pm
¡Fíjate!
I had only moved the .minimum = x statement around not the whole .AutomaticMimimum stuph.... This did do the trick!
¡Gracias por tu ayuda e igualmente!
-cg :)
