ticks don't align with series in bar chart
ITGIWM
Post by ITGIWM » Mon Jul 23, 2007 4:13 pm
We've been running into a problem for quite some time now, where the ticks on the horizontal axis of a TeeChart don't line up with the series data in a bar graph. The ticks are actually placed slightly to the right of the bar.
For example, the graph shown contains a series of data in which all X-points are 0. However, the 0 tick is shown slightly to the right of the bar (making the points appear to be negative, when they are all actually 0).
Any ideas on how to get these ticks to line up with the data they represent?
Thanks!
Post by Pep » Fri Jul 27, 2007 3:22 pm
which TeeChart version are you using ?
I cannot reproduce the problem here, would you be so kind to post the code you are using in order to see the problem ?
