Point Series appear behind axes
Simon
Post by Simon » Tue Mar 30, 2004 3:52 pm
How can you get the plots for the point series to be displayed on top of the axes?
They are always clipped by the axes unless you set the gradient of the series to radial - but I don't always want them to have a gradient.
Also, how do you set the end colour for the gradient? I can only see how to set the start and middle colours
Post by Pep » Tue Mar 30, 2004 9:54 pm
Hi Simon,
Using the ClipPoints property as in the example below.
You should be able to set it as in the following example :
Private Sub Form_Load()
With TChart1
    .AddSeries scPoint
    .Series(0).FillSampleValues (5)
    .ClipPoints = False
    .Series(0).asPoint.Pointer.Gradient.StartColor = vbBlue
    .Series(0).asPoint.Pointer.Gradient.MidColor = vbYellow
    .Series(0).asPoint.Pointer.Gradient.EndColor = vbRed
    .Series(0).asPoint.Pointer.Gradient.Visible = True
End With
