Has anyone seen this behavior before.
I am generateing a chart that uses strictly custom axes, and when the chart is generated the axis label is overlapping the axis title. This makes the axis title unreadable. I have the title size property for each axis set to zero, I tried setting this to another value, but it had no effect. For the x axis, the labels are set at an angle of 90 degrees and on the y axis the title is set at a 90 degree.
Does anyone have any idea what is going on here?
Axis Label is overlapping Axis Title
to solve this you must increase the Axis labels size using :
tChart1.Axis.Bottom.Labels.Size = X
Pep Jorge
http://support.steema.com
Axis Labels Size
Will there be a solution to the "axis labels overlapping axis title" problem?
My labels more or less always overlap the axis title when axis values are large or when using the OnGetAxisLabel event to override axis labels (using axis.labels.width=0)
If the automatic width of the labels where calculated after the OnGetAxisLabel was triggered for all labels then probably everything would be fine.
/ Fredrik
/ Fredrik
