hello,
how can I make the bottom axis scroll this way:
- I have automatic scale OFF and set fixed number of data points (1000)
- I add data values every second
- when e.g. 800 data points have been added, the bottom axis should start scrolling, but NOT losing the data points --> also manual scrolling should be enabled to scroll previous values
I use TeeChart Pro ActiveX version 6.0.0.4 in ASP pages. I use scLine for drawing the chart and addXY method for adding the data points.
Mike
Bottom axis scrolling
Hi Mike,
you can use similar code like in the following example :
Dim LMax
Private Sub Form_Load()
With TChart1
.Aspect.View3D = False
.AddSeries scLine
For i = 37000 To 37000 + (2 / 1440) Step (1 / 86400)
.Series(0).AddXY i, Rnd * 100, "", clTeeColor
Next i
.Series(0).XValues.DateTime = True
.Axis.Bottom.Labels.DateTimeFormat = "dd/mm/yy hh:mm:ss"
.Axis.Bottom.Labels.Angle = 90
.Axis.Left.StartPosition = 50
End With
'Data added in "real time"
With TChart1
.AddSeries scLine
.Series(1).XValues.DateTime = True
.Series(1).VerticalAxis = aRightAxis
.Series(1).HorizontalAxis = aTopAxis
.Axis.Top.Labels.DateTimeFormat = "dd/mm/yy hh:mm:ss"
.Axis.Top.Labels.Angle = 90
.Axis.Right.EndPosition = 50
.TimerEnabled = True
.TimerInterval = 1000
.Axis.Top.SetMinMax Now, Now + (2 / 1440)
.Axis.Right.SetMinMax .Series(0).YValues.Minimum, .Series(0).YValues.Maximum
LMax = Now + (2 / 1440)
End With
Private Sub TChart1_OnTimer()
With TChart1
.Series(1).AddXY Now, Rnd * 100, "", clTeeColor
If .Series(1).XValues.Maximum >= LMax Then
.Axis.Top.SetMinMax Now - (2 / 1440), Now
End If
End With
Pep Jorge
http://support.steema.com
