I need to display several kind of data on a line chart. To show these latest values, I create Annotations for each data and put them on the top-right position.
In the screen, everything look just fine. However, these Annotations will overlape the main body of the line chart, when I print it.
There is no way to adjust, because these position will be different on each printing size.
The Annotation tool change position automatically
Hi ivan,
So that the annotations are placed properly when printing you should put them in a position relative to some chart object, for example: axis, legend, series, ChartRect, etc.
