TeeChart ActiveX v7.0.1.2 and new Unicode version available
Post by Narcís » Tue Oct 17, 2006 1:35 pm
Steema Support Central writes to inform you of the availability of the latest TeeChart ActiveX v7.0.1.2 maintenance release and the new TeeChart ActiveX v7.0.1.2 Unicode. TeeChart ActiveX v7 customers may download the version at no-charge from the customer download page via:
http://www.steema.com/downloads/client_access.html
The maintenance release contains several bugfixes and improvements. Release notes may be viewed here:
http://www.steema.com/files/activex/public/Release.txt
A reminder too that the latest release of TeeChart ActiveX v7.0.1.2 is available for evaluation via:
http://www.steema.com/downloads/dwn_tch_ax.html
Ajith Nair
Error with version 7.0.1.3
Post by Ajith Nair » Fri Jan 12, 2007 12:18 pm
I installed latest version 7.0.1.3. but with my software when I load huge data sets, software gets hanged. But with 7.0.0.4 version which was used earlier, there is no problem.
may I know the problem with the latest version.
Thanks in advance,
Ajith
Post by Pep » Mon Jan 15, 2007 9:23 am
Hi Ajith,
would you be so kink to send me an example with which I can reproduce the problem here in order to see what could we change and try to fix it ?
You can send me it directly to pep@steema.com
