OnCursorToolChange not called when changing cursor position
nico193
Post by nico193 » Tue Mar 02, 2004 9:59 am
The event OnCursorToolChange is called when the user is changing the cursor tool position, but not when the position is changed programmatically.
Is there a way to invoke this event when changing the position of the cursor tool programmatically ? I need to retrieve the nearest point index of the cursor tool.
Thanks for help
nico193
Post by nico193 » Wed Mar 03, 2004 4:16 pm
I'm working with Tee Chart Active X V5
Post by Pep » Wed Mar 03, 2004 5:57 pm
Hi nico,
yes, you're correct, it's a bug. It has been added on our defect list and a fix for it will be considered to inclusion for the next maintenance releases.
>Is there a way to invoke this event when changing the position of the >cursor tool
The only way I can think of is to create your custom Sub and call it after the X or YValue of the CursorTool has changed.
