Y-Axis Increment
Posted: Thu Sep 21, 2006 5:47 am
by 9080944
We have just upgraded from TeeCharts v6 to v7.
v7 is excellent and contains many new features which we will make use of however we have noticed one thing almost straight away.
In v6 (Line series) the Y-Axis would auto-increment to a round figure, for example if the max value was 50,000, v6 would create increments at every 10,000 etc.
This is not occuring with v7, instead TeeCharts will auto increment to a very odd figure. This causes the display to show numbers which are not rounded to the nearest, hundred, thousand or ten thousand (depending upon the data loaded).
Please note that there was no change in code from v6 to v7, we simply used the conversion tool to upgrade to the new version.
Lastly, the "Desired Increment" setting is 0.
Any ideas why this changed or how TeeCharts can display rounded figures in the Y-Axis?
Kind Regards
Anthony
Posted: Thu Sep 21, 2006 6:33 am
by 9080944
Please ignore my post, we managed to sort everything out.
Kind Regards
Anthony
