Converting Axis to Log Scale
Faizullah Khan
Post by Faizullah Khan » Fri Jul 28, 2006 6:53 am
When we convert the Y-Axis or X-Axis to log scale then Axis values (label values on axis) overlaped.
Thanks & Regards
Post by Narcís » Fri Jul 28, 2006 7:42 am
Hi Faizullah,
I'm not able to reproduce this issue here using TeeChart Pro v7.0.0.8 ActiveX. Could you please send us some code or an example we can run "as-is" to reproduce the problem here and let us know which TeeChart version you are using?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup.
Faizullah Khan
Post by Faizullah Khan » Tue Aug 01, 2006 3:38 pm
When we assign minimum and maximum value to axis. like using this code
For i = 0 To 500
        TChart1.Series(0).AddXY i + 2, i + 5, "", clTeeColor
   Next
 TChart1.Axis.Left.AutomaticMaximum = True
  TChart1.Axis.Left.AutomaticMinimum = True
  TChart1.Axis.Left.Minimum = 0
  TChart1.Axis.Left.Maximum = 500
  TChart1.Axis.Left.Increment = 5
  TChart1.Axis.Left.Labels.ValueFormat = "0.00e+00"
And change the Y-axix to log scale then values of axis are over laped.
Thanks & Regard
Faizullah Khan
Post by Faizullah Khan » Tue Aug 01, 2006 3:42 pm
We are using TeeChart v7.0.0.7 .
Thnaks & Regards
Post by Pep » Thu Aug 03, 2006 9:52 pm
yes, you're correct , it's a known issue. For the moment a workaround is to use custom labels when logarithmic is set to true, displaying only the desired labels.
We'll try to improve this for the next releases.
Faizullah Khan
Post by Faizullah Khan » Thu Sep 07, 2006 3:56 pm
I am unable to understand assignment of custom labe.l
so kindly provide an example of custom labels for axis.
For this line of code how we assign custom labels for the Y-Axis
For i = 0 To 500
   Next
 TChart1.Axis.Left.AutomaticMaximum = False
  TChart1.Axis.Left.AutomaticMinimum = false
Thanks & Regards
Post by Narcís » Thu Sep 07, 2006 4:02 pm
Hi Faizullah,
To use custom labels feature you should do as in the All Features\Welcome!\Axes\Lables\Custom Labels example in the features demo. You'll find the demo at TeeChart's program group.
