Anything in ActiveX to work like .NET's ColorLine events?
Midnightprowler
Post by Midnightprowler » Fri Feb 20, 2004 3:06 pm
.NET TeeChart has DragLine and EndDragLine events for Steema.TeeChart.Tools.ColorLine. I can't seem to find anything that will work when i move a colorline in ActiveX 6. Any help?
Post by Pep » Mon Feb 23, 2004 9:55 am
There are no TeeChart events associated with the ColorLine Tool. The movement of it can be tracked, however - see my code below for how to do this.
Dim MyX As Long
Dim Go, Start As Boolean
Private Sub Form_Load()
Start = True
With TChart1
    .Aspect.View3D = True
    .Aspect.Chart3DPercent = 100
    .AddSeries scLine
    .Series(0).FillSampleValues 100
    .Tools.Add tcColorLine
    .Tools.Items(0).asColorLine.Axis = .Axis.Bottom.AxisType
    .Tools.Items(0).asColorLine.AllowDrag = True
    .Tools.Items(0).asColorLine.Value = 30
    .Tools.Items(0).asColorLine.DragRepaint = True
    .Tools.Items(0).asColorLine.Pen.Visible = False
End With
With TChart1
    If Go = True Then
        .Canvas.Brush.Color = vbYellow
        .Canvas.BackMode = cbmOpaque
        .Canvas.Plane3D MyX, .Axis.Top.Position, MyX, .Axis.Bottom.Position, 0, .Aspect.Width3D
    End If
    If Start = True Then
        If MyX = 0 Then
            MyX = .Series(0).CalcXPosValue(30)
        End If
        Start = False
    End If
End With
Private Sub TChart1_OnMouseDown(ByVal Button As TeeChart.EMouseButton,
ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
With TChart1
    If .Tools.Items(0).asColorLine.Clicked(X, Y) = True Then
        Go = True
    End If
End With
Private Sub TChart1_OnMouseMove(ByVal Shift As TeeChart.EShiftState,
If Go = True Then
    MyX = X
    MyY = Y
    TChart1.Repaint
End If
Private Sub TChart1_OnMouseUp(ByVal Button As TeeChart.EMouseButton,
If Go = True Then
    Go = False
    TChart1.Repaint
End If
If Start = False Then
    Start = True
    TChart1.Repaint
End If
