OnAfterDrawChart not working as expected
Vivo
Post by Vivo » Thu Jun 29, 2006 2:27 pm
I've just tried to use OnAfterDrawChart() and it acts strangely. I can see the test object show up but it is immediatly replaced by the stuff I just covered up, as if an invalidate has occured but without causing the OnAfterDrawChart() to be reinvoked. Why would this be? Here is the code fragment:
void CTest::OnAfterDrawChart()
   CTChart & tchart = GetTChart();
   CRect rect(0, 0, 300, 300);
   CDC& dc = *tchart.GetDC();
   dc.SelectStockObject(NULL_BRUSH);
   dc.Rectangle(rect);
   tchart.ReleaseDC(&dc);
Adrian
Post by Narcís » Thu Jun 29, 2006 2:32 pm
Hi Adrian,
When initializing the chart you'll have to call m_Chart1.GetEnvironment().InternalRepaint(); so that OnAfterDraw event is fired.
Vivo
Post by Vivo » Thu Jun 29, 2006 2:37 pm
Hi Narcís,
The event was already being fired, and after I used the InternalRepaint() call it didn't make a difference. I can see the test object showing up, but it gets painted over.
Any ideas?
Adrian
Post by Pep » Wed Jul 05, 2006 2:57 pm
Hi Adrian,
I'm not sure what are you trying to accomplish, would you be so kind to explain me and I'll try to replicate it here and try to find a solution (if exists) ?
Vivo
Post by Vivo » Wed Jul 05, 2006 3:13 pm
It is OK. I found a way to get the canvas DC on which I can draw directly on.
Adrian
