Totally beaten by SeriesXMLSource
David
Post by David » Wed May 31, 2006 8:55 am
Hi, there,
Here is part of the code in the Tutorial 15 - MS VC++ Applications:
m_SeriesXMLSource1.SetFileName("http://www.steema.com/SampleData.xml");
m_SeriesXMLSource1.SetSeries(SourceSeries);
m_SeriesXMLSource1.SetSeriesNode("USA");
m_SeriesXMLSource1.SetValueSource("Bar");
m_SeriesXMLSource1.Open();
It can works. But when I changed it to
m_SeriesXMLSource1.SetSeriesNode("Revenue");
m_SeriesXMLSource1.SetValueSource("Line");
(<series title="Revenue" type="Line" color="#FF0000"> as in the http://www.steema.com/SampleData.xml)
It won't work. Why? And that's the only VC++ code on SeriesXMLSource I could find. I tried so many times trying to use the VC code in the tutorial with my own xml files but I just could make it.
Would anyone please give me an example of how to import a xml file that has several series data and display in one chart? Is it possible to import several different xml files each of which has only one series, then display in one chart?
VC++ code please!!
Thank you very much!
David
Post by Pep » Thu Jun 08, 2006 11:40 am
Hi David,
The correct code for Line Series should be :
m_SeriesXMLSource1.SetValueSource("Y");
Could you please check if it works fine for you using the above code ?
You can use the following code (vb code) :
Private Sub Command3_Click()
  With SeriesXMLSource1
    .FileName = "http://www.steema.com/SampleData.xml"
    .Chart = TChart1
    .Load      '<-- retrieve data and create series
  End With
Yes, this can be done using one SeriesXMLSource, by assigning the parameters every time the Open is called, i.e :
TChart1.AddSeries scLine
TChart1.AddSeries scBar
SeriesXMLSource1.LoadMode = lmAppend
with SeriesXMLSource1
.Series = TChart1.Series(0)
.SeriesNode = "Revenue"
.ValueSource = "Y"
.Open
.FileName = "http://www.steema.com/SampleData2.xml"
.Series = TChart1.Series(1)
.SeriesNode = "USA"
.ValueSource = "Bar"
.Open
end with
David
Post by David » Fri Jun 09, 2006 1:25 am
Hi, Pep,
Thank you very much for your help. I tried to translate the last part of your post to C++ as below
VARIANT SourceSeries;
m_chart2.AddSeries(0);
m_chart2.GetLegend().SetCheckBoxes(TRUE);
SourceSeries.vt=VT_DISPATCH;
CSeries InputSeries=m_chart2.Series(0);
SourceSeries.pdispVal=InputSeries;
m_XMLSource1.SetFileName("http://www.steema.com/SampleData.xml"); //This can also be a local file
m_XMLSource1.SetSeries(SourceSeries);
m_XMLSource1.SetSeriesNode("Expenses");
m_XMLSource1.SetValueSource("Y");
m_XMLSource1.Open();
InputSeries=m_chart2.Series(1);
m_XMLSource1.SetSeriesNode("Revenue");
It seems working, but I can't find the corresponding code for
Is it needed in C++? Did I come up with the correct way to import several different xml files and display them in one chart?
thanks again.
David
David
Post by David » Fri Jun 09, 2006 1:34 am
BTW, I also asked another question in C++. Would you please help me have a look?
http://www.teechart.net/support/viewtopic.php?t=4154
