label format repeating
Ajith Nair
Post by Ajith Nair » Wed Apr 19, 2006 1:42 pm
in y-axis, label is showing repetedly if there is only one decimal point is assigned as format(#0.0). if I change to (#0.0#) then its not.
Eg. 7.1, 7.1, 71, 7.2, 7.2 and so on. I just want to show 7.1, 72, 7.3 ..... only.
Thanks in advance,
Ajith
Post by Narcís » Wed Apr 19, 2006 1:55 pm
Hi Ajith,
To solve that you can set the axis increment like this:
    TChart1.Axis.Left.Increment = 0.1
Ajith Nair
Post by Ajith Nair » Wed Apr 19, 2006 2:00 pm
hi,
But how can I count that I have more than one from the same label?
B Regards
Ajith
Post by Narcís » Wed Apr 19, 2006 2:05 pm
Hi Ajith,
In that case what would you like to have? Can you please elaborate on that?
Ajith Nair
Post by Ajith Nair » Wed Apr 19, 2006 2:13 pm
First I want to count the repetition of label. If I have more than one, I can change the format to "#0.0#". otherwise I can continue with "#0.0"
Ajith
Post by Pep » Mon Apr 24, 2006 9:49 am
Hi Ajith,
the best way to check this or to customize the axis labels is by using the OnGetAxisLabel event which will return the labeltext of each axis :
Private Sub TChart1_OnGetAxisLabel(ByVal Axis As Long, ByVal SeriesIndex As Long, ByVal ValueIndex As Long, LabelText As String)
If Axis = 0 Then
If LabelText = ....
end if
end Sub
