ToolTip,No Transparency,Milestones
Yael
Post by Yael » Sun Apr 02, 2006 7:34 am
The code is written at ASP+ Visual Basic.
Please recommend on method to execute a tool tip which will reflect the data on the process line shown on the teeChart onmouseOver event.
Additional problem is that there is no transparency between two process that are received parallel , therefore there is a confusion which line belongs where.
Is there any way to adjust the milestones, so that there will not be shown the default options, like series 2, for instance?
Is there any option to change the icon of the given milestones? We would like to make it just *? Where these icons are and how do I access them?
Post by Narcís » Mon Apr 03, 2006 9:35 am
Hi here4u,
I've already sent you an ASP+VB example on how to use a MarksTip tool. Regarding your other questions, could you please be more specific as I don't understand what are you trying to achieve.
Yael
Use tooltip
Post by Yael » Thu Apr 06, 2006 1:33 pm
Hi Calvet ,
Can you please send me the ASP+VB example on how to use a MarksTip
tool ?
I'm facing the same problem.
Yael[/b]
Post by Narcís » Thu Apr 06, 2006 2:00 pm
Hi Yael,
I thought you had already sent me an e-mail and I had replied with the example. Anyway, I already sent the example to your forums contact e-mail address
Yael
RE
Post by Yael » Sun Apr 09, 2006 11:18 am
Hi Calvet ,
My Profiles e-mail address was incorrect
can you please send me the examples again.
I updated the right address in the profile.
Thanks again
Yael.
Post by Narcís » Mon Apr 10, 2006 8:42 am
Hi Yael,
Ok, done!
stl
Re: ToolTip,No Transparency,Milestones
Post by stl » Wed Oct 21, 2009 3:32 pm
I am trying to get the Markstip working on an asp or aspx page't.
Could you please send me an example?
Post by Yeray » Thu Oct 22, 2009 11:38 am
Hi stl,
We've just sent it to your registered mail at this forums.
For other customers interest, here it is attached the example mentioned.
MarksTipTool.zip
(865 Bytes) Downloaded 423 times
