I am using TeeChart 6 in VB6. I have a button that does the following:
With tchUnbalanceVsSpeed
.Series(gintLEFT).Clear
.Series(gintRIGHT).Clear
.Series(intUnCorrectable).Clear
.Series(intTolerance).Clear
.Series(intUnbVsSpdCalSpd).Clear
End With
With tchAngleVsSpeed
.Series(intAngVsSpdCalSpd).Clear
End With
Everything does clear EXCEPT the Marks on a series AND I have the values of those marks showing on the Axis both left and bottom. This is not necessarily a bad thing, but the values show decimal points and they should not. I guess I am looking for a way to clear the axis all together of numbers OR a way to display the values without decimals. Now keep in mind the values on the axis do not normally show decimals.
Problem with marks and axis clearing...
Hi Jeff,
Could you please send us an example we can run "as-is" to reproduce the problem here?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup.
