Unable to use Tchart in Windows 2003 server SP1
Roger
Post by Roger » Fri Dec 02, 2005 1:05 pm
We have developed an application on Windows XP with Tchart(TeeChart Pro v7.0.0.5) control and the application works file in XP. But once we install the application on Microsoft 2003 server standard edition with Service Pack 1, we are unable to view the charts.(Not able to create the Tchart templates at runtime).
Could you please let us know if Teechart(TeeChart Pro v7.0.0.5) is compatible with Microsoft 2003 server standard edition with Service Pack1.
If not please let us know the alternative solution so that we can use our application in 2003 server.
Thanks and Regards,
Mahendra
Post by Pep » Fri Dec 02, 2005 7:10 pm
Hi Roger,
it's really strange, yes TeeChart Pro ActiveX should be compatible with Windows Server 2003 Standard, it works fine here with Windows 2003 Server Enterprise Edition with Service Pack 1. Could you please check if it happens in another machine ? Also, if you still having problems, which error are you getting ?
