how to add waterfall series by Ax5 in htm
hi,sir
I know it 's easy to draw a waterfall series in vb by Ax5 ,but now i feel some trouble in drawing a waterfall series in htm
somebody help me,better give me some source example or some suggestion.
thanks a lot,
thanks a lot,
Hi Richard,
yes, check this one :
<html>
<head>
<title>TeeChart Pro Internet Examples</title>
<LINK REL=STYLESHEET TYPE="text/css" HREF="style.css"></head>
<body bgcolor=#FFFFFF>
<script language="VBScript">
SUB FillChart
'sets up Chart to print from IE's print option
Chart1.Environment.IEPrintWithPage=True
Chart1.RemoveAllSeries
Chart1.AddSeries( 33 )
Chart1.Series(0).Title="My WaterFall"
Chart1.Series(0).Clear
dim x,z as Integer
' Add Data here tChart1.Series(0).AsWaterFall.AddXYZ...
Chart1.Legend.Alignment=2
Chart1.Panel.Gradient.Visible=True
Chart1.Aspect.Chart3DPercent=70
Chart1.Walls.Left.Pen.Color=RGB(0,0,255)
Chart1.Walls.Left.Size=8
Chart1.Walls.Bottom.Size=8
Chart1.Walls.Back.Color=RGB(200,150,200)
Chart1.Axis.Bottom.Labels.Font.Size=12
Chart1.Axis.Bottom.Ticks.Width=2
Chart1.Axis.Bottom.Ticks.Color=RGB(200,150,200)
Chart1.Series(0).Marks.Frame.Color=RGB(200,150,200)
Chart1.Panel.BevelOffset=5
Chart1.Header.Font.Size=12
Chart1.Header.Font.Bold=True
END SUB
</script>
<p>
<font face="Arial" color="#004080"><em><big><strong>Basic VBScript
Example</strong></big></em></font></h3>
</p>
<p>
See below an embedded TeeChart Pro ActiveX control using the
HTML < OBJECT > tag.
</p>
<p>
Click the following buttons to add Chart Series and values to
the control, as well as to show the Chart editor, print preview
and export dialogs.
</p>
<p>
Note: The TeeChart Pro ActiveX control file (TEECHART.OCX), should
be present and registered in this machine to see the embedded object.
</p>
<p>
<input type="button" value="Add a Series and fill values" onclick="FillChart"
name="cdmChart1">
<input type="button" value="Show TeeChart Editor dialog" onclick="Chart1.ShowEditor"
name="cdmChart2"> </p>
<p><input type="BUTTON" value="Show TeeChart Print Preview"
onclick="Chart1.Printer.ShowPreview"
name="cdmChart3">
<input type="button" value="Show TeeChart Export dialog" onclick="Chart1.Export.ShowExport"
name="cdmChart4"> </p>
<p>
<object
id="Chart1"
width="400"
height="268"
type="application/x-oleobject"
hspace="0"
vspace="0"
classid="CLSID:B6C10489-FB89-11D4-93C9-006008A7EED4">
</object>
</p>
<p>
Click on a cylinder Bar point above.
</p>
</body>
</html>
Pep Jorge
http://support.steema.com
hi,pep
thank you very much,
you are better helper,your code is very useful.I refer to your code ,I have realize some functions.but now i want to draw like figure1 in vbscript,then figure is make by VB's paintbox
the Z-Axis is datetime,and with the time is changing,the new ArrayxyZ should be add into the chart,but hte new ArrayXYZ have the same Z,that's the time of NOW,and how to set the Zvalue-formatdatetime,at the same time ,how can i set MaxMinvalue of Z-axis.
you can check my code.
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=gb2312">
<script language="JavaScript" type="text/javascript">
<!--关键在这个函数-->
function GetData()
url="Wave.asp?IDval="+document.form2.selectCh.options(document.form2.selectCh.selectedIndex).id;//调用页面及通道ID
var http = new ActiveXObject("Microsoft.XMLHTTP");
http.open("POST",url,false);
http.send();
var str = http.responseText;
//loadcontent.innerHTML=str;
DrawWave(str);
</script>
<script language="JavaScript" type="text/JavaScript">
function MM_reloadPage(init) { //reloads the window if Nav4 resized
if (init==true) with (navigator) {if ((appName=="Netscape")&&(parseInt(appVersion)==4)) {
document.MM_pgW=innerWidth; document.MM_pgH=innerHeight; onresize=MM_reloadPage; }}
else if (innerWidth!=document.MM_pgW || innerHeight!=document.MM_pgH) location.reload();
MM_reloadPage(true);
</script>
<style type="text/css">
</style>
</head>
<div id=loadcontent>Data is Loading……</div>
<body >
<table width="878" height="35" cellpadding="0" cellspacing="0" >
<tr>
<td><table width="732" cellpadding="0" cellspacing="0">
<tr>
<td width="160"> </td>
<td width="570"><table border="0"cellpadding="0" cellspacing="0"><tr><td></td></tr><tr><td><object
id="TChart1"
width="570"
height="405"
hspace="0"
vspace="0"
codebase="http://www.envada.com.cn/en8000web/Teechart5.cab#version=5,0,4,0">
</object></td></tr></table></td>
</tr>
</table>
</td>
</tr>
</table>
<script language="vbscript">
Dim Sendstr,ChnStr
Dim FunFlag,RealFlag
Dim wavestr
sub Window_onload()
Dim tmpIndex
TChart1.Environment.IEPrintWithPage=True <!--sets up Chart to print from IE's print option -->
TChart1.AutoRepaint=True
TChart1.AddSeries(33)
<!-- 表头-->
TChart1.Header.Text.Clear
TChart1.Header.Text.Add("1瓦X向轴振")
TChart1.Header.Font.Bold=True
TChart1.Header.Font.Color=vbBlue
TChart1.Header.Font.Size=12
TChart1.Header.Alignment=2 '0-left,1-right,2-center,defause-2'
<!-- 表底-->
TChart1.Footer.Text.Clear
TChart1.Footer.Text.Add("周期:T")
TChart1.Footer.Font.Italic = False
TChart1.Footer.Font.Bold=True
TChart1.Footer.Font.Color=vbBlue
TChart1.Footer.Font.Size=8
TChart1.Footer.Alignment=1
TChart1.Aspect.Orthogonal =False
TChart1.Aspect.Chart3DPercent =100
TChart1.Aspect.Zoom = 80
TChart1.Panel.Gradient.Visible=False
'TChart1.Series(0).asWaterfall.UsePalette=False'
TChart1.Series(0).asWaterfall.WireFrame=True
TChart1.Series(0).asWaterfall.Pen.Color=vbBlue
TChart1.Series(0).asWaterfall.WaterLines.Visible=False
TChart1.Walls.Left.Pen.Color=RGB(0,0,128)
TChart1.Walls.Left.Size=0
TChart1.Walls.Back.Color=RGB(242,242,242)
TChart1.Walls.Bottom.Size=1
TChart1.Axis.Bottom.Labels.Font.Size=12
TChart1.Axis.Bottom.Ticks.Width=2
TChart1.Axis.Bottom.Ticks.Color=RGB(200,150,200)
TChart1.Panel.BevelOffset=5
TChart1.Panel.Color=vbWhite '15921906'
TChart1.Zoom.Animated=True
TChart1.Zoom.Pen.Color= vbYellow
TChart1.TimerEnabled=True
TChart1.TimerInterval=1500
end sub
// the procedure Draw
sub DrawWave(wavestr)
dim rat,smplen,smpcyc,valnum
dim MyArray
dim MyValArray(),MyPhaArray(),My1XArray(),MyXArray(),MyYArray(),MyZArray()
dim i,j,k,n,m
dim MaxnX,MaxVal
dim tm
On Error Resume Next
MyArray=split(trim(wavestr),",",-1,1)
rat=Myarray(0)
smplen=MyArray(1)
smpcyc=MyArray(2)
valnum=MyArray(3)
n=CInt(valnum)
if n>0 then
Redim MyValArray(n),MyPhaArray(n),MynXArray(n)
for i=0 to n-1
MyValArray(i)=MyArray(3*i+4)/10
MyPhaArray(i)=MyArray(3*i+5)
MynXArray(i)=MyArray(3*i+6)
Next
MaxnX=CInt(MynXArray(0))
for i=1 to n-1
if MaxnX<CInt(MynXArray(i)) then
MaxnX=CInt(MynXArray(i))
end if
next
Redim MyXArray(MaxnX+smpcyc),MyYArray(MaxnX+smpcyc),MyZArray(MaxnX+smpcyc)
m=MaxnX+smpcyc
tm=now
for i=0 to m-1
MyXArray(i)=i/smpcyc
MyYArray(i)=FormatNumber(Rnd,2)
MyZArray(i)=tm
next
for i=0 to n-1
MyYArray(MynXArray(i))=MyValArray(i)
next
TChart1.Series(0).asWaterfall.IrregularGrid=True
TChart1.Series(0).asWaterfall.AddArrayXYZ MyXArray,MyYArray,MyZArray
MaxVal=TChart1.Axis.Left.MaxYValue+10
document.form1.textY.value=MaxVal
MaxXVal=TChart1.Axis.Bottom.MaxXValue
TChart1.Axis.Left.SetMinMax 0,MaxVal
TChart1.Axis.Bottom.SetMinMax 0, MaxXVal
TChart1.Repaint
end if
end sub
sub TChart1_OnTimer()
dim temstr1,temstr2,temstr3,temstr
temstr1="10,1024,16,18,621,0,16,77,150,92,76,70,32,74,211,112,72,289,144,69,271,136,"
temstr2="69,190,104,68,230,120,67,129,88,66,90,40,65,30,8,63,249,128,63,100,20,62,107,48,62,"
tempstr3="308,152,61,55,12,61,169,96,55,50,24"
temstr=temstr1+temstr2+temstr3
TChart1.TimerEnabled=False
DrawWave(temstr)
end sub
sub ShowPrints()
TChart1.Printer.ShowPreview
end sub
sub Exportbmp()
TChart1.Export.ShowExport
end sub
sub Pause()
if TChart1.TimerEnabled then
TChart1.TimerEnabled=false
document.form1.CmdPause.value="刷新"
TChart1.TimerEnabled=true
document.form1.CmdPause.value="暂停"
end if
end sub
<!-- 通道选择-->
sub SelectChannel()
dim headertext
TChart1.Series(0).Clear
TChart1.AutoRepaint=False
headertext=document.form2.selectCh.options(document.form2.selectCh.selectedIndex).Value
TChart1.Header.Text.Add(headertext)
end sub
sub TChart1_OnCursorToolChange(Tool, X, Y, XVal, YVal, Series, ValueIndex)
document.form1.textX.value=FormatNumber(XVal,1)+"T"
document.form1.textY.Value= FormatNumber(YVal,0)+"um"
end sub
</script>
</body>
</html>
Hi Richard,
you can use similar code to the following :
TChart1.Axis.Depth.Visible = True
TChart1.Series(0).asWaterfall.ZValues.DateTime = True
TChart1.Axis.Depth.Labels.DateTimeFormat = "hh:mm:ss"
TChart1.Axis.Depth.SetMinMax Now, Now + 1
Pep Jorge
Hi Richard,
yes, sorry, don't remember you're using the AX v5. Using this version the depth axis still showing the values as longint even DateTime property is set to true. To solve this you must reasign the axis labels in the OnGetAxisLabel event :
This has been fixed in the TeeChart Pro v6 and above.
Private Sub TChart1_OnGetAxisLabel(ByVal Axis As Long, ByVal SeriesIndex As
Long, ByVal ValueIndex As Long, LabelText As String)
Date = CDate(LabelText)
LabelText = Date
Pep Jorge
hi ,pep
yeah,I use the AV5.
i have added your code in my program written by VBScript in htm ,but likely it does't work
i don't know what's wrong with it.
Check my code.
[/code]
yeah,I use the AV5.
Check my code.
sub TChart1_OnGetAxisLabel(Axis, SeriesIndex, ValueIndex, LabelText)
dim MyDate
'In vbscript ,atDepth=4'
if Axis=4 then
MyDate = CDate(LabelText)
LabelText =MyDate
end if
end sub
Hi Richard,
This seems to be a limitation of ActiveX Controls in HTML in that the value
of strings in event handlers is lost. There is a workaround to this problem,
however, which can be seen in the ASP Server examples (accessible from the TeeChart Pro AXv5 Program Group) in the example "Page showing 4 different export formats", specifically the text on the left axis in the first "live" example.
Upgrading your license to TeeChart Pro v7 ActiveX would solve your problem just using:
tChart1.Series(0).AsWaterFall.ZValues.DateTime = true
Hi Richard,
Here is the on-line order web page to upgrade from v5 to v7. v7 includes tools to authomatically upgrade your applications for v6 to v7. If necessary, we will send you the tools to upgrade from v5 to v6 too.
Hi Richard,
If you want to update to v6 please contact our Sales Dept. at sales@steema.com. Then you can download what you exactly need from our download area.
