When exporting a TeeChart graph (scatter plot) as an SVG file the Y axis title is not rotated 90 degrees and so overlaps with Y axis labels and the Y axis itself. Exporting as a bitmap then the Y axis label is rotated fine.
Is this bug going to be fixed?? We use the SVG export to embed graphs in PDF reports using FOP (bitmaps are too jaggy) and the graphs with Y axis titles like this are not acceptable
SVG export - Y axis title rotation
Hi Minty,
This is a problem we are aware of and it has a high priority on our bug-list to be fixed for future releases. There's no workaround we can think of for now.
