Axis labels on bottom axis jammed for horizontal bar
If we use, for example, values 0,1,2,3,4,5,6 to build a horizontal bar, automatic labels for the bottom axis overlap for most sizes of the window. If we use 1e-5,2e-5,3e-5,4e-5,5e-5,6e-5,7e-5 it formats and places labels fine.
Hi Alex,
I'm not able to reproduce it here using the code below:
Does this code works for you? Please feel free to modify it so that we can reproduce the proble here.
With TChart1.Series(0)
For i = 0 To 6
.Add i, "", clTeeColor
Next
End With
Narcís,
Here is a c# code which exports BMP with jammed labels.
using System;
using TeeChart;
namespace tee_test
/// <summary>
/// Summary description for Class1.
/// </summary>
class Class1
/// <summary>
/// The main entry point for the application.
/// </summary>
[STAThread]
static void Main(string[] args)
ITChart pChart = new TChartClass();
pChart.ClearChart();
int idx = pChart.AddSeries(ESeriesClass.scHorizBar);
pChart.Aspect.View3D = false;
pChart.Legend.Visible = false;
pChart.Header.Visible = false;
ISeries pSeries = pChart.Series(idx);
pSeries.Marks.Visible = false;
for (int i = 0; i < 7; i++)
pSeries.Add(i, null, 0xffffff);
IBMPExport pBMP = pChart.Export.asBMP;
pBMP.Height = 250;
pBMP.Width = 600;
pBMP.SaveToFile("c:\\tee_testJam.bmp");
using System;
using TeeChart;
namespace tee_test
/// <summary>
/// </summary>
class Class1
/// <summary>
/// </summary>
[STAThread]
pBMP.Height = 250;
pBMP.Width = 600;
Hi Alex,
Yes, I've been able to reproduce that and added the issue (TV52011014) to our defect list to be fixed for future releases. I've found that another workaround is setting pChart.Axis.Bottom.Labels.Style = EAxisLabelStyle.talMark as shown here:
Another solution is increasing bottom axis increment:
static void Main()
pChart.Axis.Bottom.Labels.Style = EAxisLabelStyle.talMark;
pBMP.Height = 250;
pBMP.Width = 600;
pChart.Axis.Bottom.Increment=0.4;
