Hi Support,
We produce a custom reporting package that uses TeeChart to produce any required trends. Teechart version 6 worked fine, but when we upgraded to TeeChart 7 a problem occurred with using multiple Y-axis. Basically, if multiple custom Y-axis are required, TeeChart appears to overwrite the fist one. For example, if 4 custom Y-axis are configured, the first (0) Y-axis would be overwritten by TeeChart using the max and min value of the trace for its scale, rather than the custom axis required. The second (1) Y axis would not appear. The three and fourth Y-axis (2 & 3) would seem alright.
Is there any difference between TeeChart versions 6 and 7 that has changed the way multiple Y-axis are created?
Thanks in advance,
Bertie
Multiple Y-Axis in TeeChart Version 7
Hi Bertie,
It seems to work fine here. Which v7 release are you using? Latest available at our Customer Download Area is v7.0.0.5.
Could you please send us an example we can run "as-is" to reproduce the problem here? You can post your files at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup.
