multiple pies - legend problem
Bjørn
Post by Bjørn » Sat Sep 03, 2005 2:12 pm
I've got multiples pies (in other word series) on a chart (more than 1 series). When this is the case the legend is of "no value" since there is no way to tell which series are which pie? Is there a way to mark each PIE with series legend?
Bjørn
More info on the subject
Post by Bjørn » Sat Sep 03, 2005 2:59 pm
I've attempted the following:
Y = 1
While y < NumberOfseries
TChart.Canvas.Brush.Color = RGB(255, 255, 255)
TChart.Canvas.Rectangle 90, 90, 200, 120
TChart.Canvas.Font.Bold = True
TChart.Canvas.TextOut TChart.Series(y - 1).asPie.XCenter, TChart.Series(y - 1).asPie.yCenter, "SERIES LEGEND IS.."
y = y + 1
wend
but the TChart.Series(y - 1).asPie.XCenter and TChart.Series(y - 1).asPie.YCenter are 0 so it does not work.
<B>Any other way to establish center of pies (x and y)?</B>
btw: if I do a
TChart.Canvas.TextOut 100, 100, "THIS IS A TEST"
nothing is printed. I've got the latest version (7.0..)
any ideas how I can accomplish this?
Post by Narcís » Mon Sep 05, 2005 11:11 am
Hi Bjørn,
You need to do something like the code below. Using TChart's OnAfterDraw event and retrieve XCenter and YCenter values to a variable before the TextOut statement.
Private Sub Form_Load()
  With TChart1
    .Legend.Visible = False
    For i = 0 To 3
      .AddSeries scPie
      .Series(i).FillSampleValues 7
      .Series(i).Marks.Style = smsValue
    Next i
  End With
    Dim XCenter, YCenter As Integer
    With TChart1
      For SeriesIndex = 0 To TChart1.SeriesCount - 1
          XCenter = .Series(SeriesIndex).asPie.XCenter
          YCenter = .Series(SeriesIndex).asPie.YCenter
          .Canvas.TextOut XCenter, YCenter, "Series" + CStr(SeriesIndex)
      Next SeriesIndex
    End With
Private Sub TChart1_OnSeriesBeforeDrawValues(ByVal SeriesIndex As Long)
  'Place the new location of the Chart before painting the Series
  With TChart1
    Select Case SeriesIndex
      Case 0: .ChartRect 0, 0, .Canvas.Width / 2, .Canvas.Height / 2
      Case 1: .ChartRect .Canvas.Width / 2, 0, .Canvas.Width, .Canvas.Height / 2
      Case 2: .ChartRect 0, .Canvas.Height / 2, .Canvas.Width / 2, .Canvas.Height
      Case 3: .ChartRect .Canvas.Width / 2, .Canvas.Height / 2, .Canvas.Width, .Canvas.Height
    End Select
  End With
Bjørn
on after draw?
Post by Bjørn » Mon Sep 05, 2005 11:20 am
Is it possible to use the onAfter draw when the project is a .DLL project (with no visible interface?)... (I just generate a JPEG in my application).
The Teechart is late bound... :?:
Post by Narcís » Mon Sep 05, 2005 11:37 am
Hi Bjørn,
Yes, TeeChart is late bound.
You can use OnAfterDraw event even you don't use a visible interface.
Bjørn
Post by Bjørn » Tue Sep 06, 2005 12:55 pm
Hola, narcis!
How?
My app is a COM+ .dll which runs as a component in component services.
I use Teechart like this:
Dim TChart As Object
' create the ole automated object...
Set TChart = CreateObject("TeeChart.TChart")
TChart.Visible = False
' and do the other bits that makes the graph and creates the file
' When I take the code you showed me (which works fine on a project with a form) i get "variable not defined" (its the "With Tchart" clause - see below.
Private Sub TChart_OnAfterDraw()
With TChart
For SeriesIndex = 0 To TChart.SeriesCount - 1
Next SeriesIndex
End With
I am doing this in VB6..
Then I move the "Dim TChart As Object" from the actual sub to the global dim part of the class. The compile error goes away so it seems fine. To debug the component - i use logging to event log and the TChart_OnAfterDraw() is not called - so nothing happens. Can this work? I have no reference other than the Dim tChart as Object - ??
regards
bjørn
Post by Pep » Sun Sep 11, 2005 10:19 pm
Hi Bjørn,
you should be able to do this by using the following code :
Option Explicit
Dim SeriesIndex As Integer
Private WithEvents TChart1 As TeeChart.TChart
Dim i As Integer
  Set TChart1 = CreateObject("TeeChart.TChart")
  With TChart1
    For i = 0 To 3
      .AddSeries scPie
    Next i
  End With
  TChart1.Export.asJPEG.SaveToFile "C:\chart.jpg"
    With TChart1
      .Canvas.Font.Color = vbWhite
      Next SeriesIndex
    End With
  With TChart1
    End Select
  End With
