* TeeChart Radar Series *
Seth
Post by Seth » Tue Aug 23, 2005 11:11 pm
we are trying to make a Radar chart.
I suspect there is an error on displaying data by circle label.
The sample project can be downloaded from here.
http://www.m2soft.co.kr/report/sjs/TeeFiles.zip
If the number of data is 13 records, the first circle label and the 13th
circle label is overlapped to each other.
If the number is 12 or 14, there was no matter.
Version is 6.0.
A quick answer would be appreciated.
Our time left is little short. Please take some time to have a look into
this.
Many thanks
ps. Please note that I posted the same inquiry on the newsgroup. Since it takes some time to get the reply, I have chosen to write on the forum as well.
Post by Pep » Mon Aug 29, 2005 7:38 am
yes, this is a kown issue. It has been fixed in the latest TeeChart Pro v7.
Seth
Post by Seth » Wed Aug 31, 2005 12:36 am
is it only applied to the version 7?
If you say that's a bug, don't you need to apply to the version 6 as well?
Post by Marc » Tue Sep 06, 2005 8:52 am
Agreed. This fix has been applied to version 6. It is being tested and will be published shortly.
Post by Narcís » Wed Sep 07, 2005 8:11 am
Hello Seth,
I have already sent you the v6 .ocx, fixing that problem, to your contact e-mail address.
