Slow Chart using Axtive X 5 C#.NET
Posted: Thu Aug 11, 2005 7:39 pm
I'm using the version 5 active x component in the .Net environment. The chart displays correctly, but when I increase the number of days along the x axis (example 30 days) the chart displays too slowly. There are many series for the chart (20 or more series). I beleive the performace issue is because the data does not contain a row for each date for each series.
To compensate for the missing data I loop through each date for each series for each record to look for a matching record for that date for that series. I want each date in the period along the x axis regardless if there where events for that day or not. Here is the loop code:
for(int i=0;i<=Ts.TotalDays;i++) // all the days in the period
for(int j=0; j<=this.DChart.SeriesCount-1;j++) // each series
foreach(DDaily dd in al) // all of my records
WeHaveAMatch = false;
if(dd.RecordName == this.DChart.Series(j).Title && dd.DDate == Convert.ToDateTime(Session["StartDate"]).AddDays(i))
{ this.DChart.Series(j).AddXY(Convert.ToDateTime(Session["StartDate"]).AddDays(i).ToOADate(),dd.TotalDSum,string.Empty,this.DChart.Series(j).Color);
WeHaveAMatch = true;
break;
if (WeHaveAMatch == false)
{ this.DChart.Series(j).AddNullXY(Convert.ToDateTime(Session["StartDate"]).AddDays(i).ToOADate(),0,string.Empty);
If there is a match in my data I add the value to the series. Otherwise I add a nullXY for the series for that day. Like I said the chart generates correct, just slow. Is there a way to get a nice looking stacked bar without having to go through so many loops? Thank you.
break;
