PowerBuilder Problems
SSW
Post by SSW » Mon May 30, 2005 7:05 am
Are there any known problems with PowerBuilder (8 Build 10784 and current
Version 10) and TeeChart ActiveX Version 7.0.0.4? Let me try to describe the
steps, which cause the error.
First I insert the ActiveX Control into a datawindow. Then Powerbuilder
crashes in these situations:
1. After saving the datawindow, I open the datawindow again and doubleclick
the ActiveX.
2. Sometimes Powerbuilder crashes when I open a datawindow which contains
the ActiveX Control. (Error Message "unknown software exeption" (0x80000003)
in der Anwendung an der Stelle 0x10d825ac aufgetreten). Additional I get
this message: "Runtime error 255 at 10BB6867".
After these Errors I must restart Powerbuilder.
Is there a memory leak?
the ActiveX.
Thanks in advance
Ciao
Roland
Post by Pep » Tue Jun 14, 2005 8:28 am
Hi Roland,
Not, that I know of. As I don't have any version of PowerBuilder installed on my machine, could you please check if the examples I've just sent to the news://steema.net/steema.public.attachments newsgroup work fine for you ?
