ITChart Draw() Exceptions
TMECHAM
Post by TMECHAM » Thu Apr 07, 2005 7:14 pm
I am calling the TChart Draw(DC, Left, Top, Right, Bottom: Integer) method and I see a range check error, sometimes. It is like I get 3 exceptions and then it draws properly. I saw a similar bug reported with printing, and wonder if this isn't a related issue.
   CRect rect = get_window_rect();
   CDC *dc = parent->GetWindowDC();
   CDC memdc;
   memdc.CreateCompatibleDC(dc);
   if(cached_bmp == 0 ||
     (bmp_width != rect.Width() || bmp_height != rect.Height()))
      if(cached_bmp)
         cached_bmp->DeleteObject();
         delete cached_bmp;
      cached_bmp = new CBitmap;
      bmp_width = rect.Width();
      bmp_height = rect.Height();
      cached_bmp->CreateCompatibleBitmap(dc,bmp_width,bmp_height);
   CBitmap *old_bmp = memdc.SelectObject(cached_bmp);
   try
      Draw(reinterpret_cast<long>(memdc.m_hDC),0,0,rect.Width(),rect.Height());
   catch(COleDispatchException *e)
      if(cached_bmp)
         delete cached_bmp;
         cached_bmp = 0;
      e->Delete();
      trace("TChart::draw() catch(COleDispatchException)");
   catch(COleException *e)
      if(cached_bmp)
         delete cached_bmp;
         cached_bmp = 0;
      e->Delete();
      trace("TChart::draw() catch(COleException)");
   memdc.SelectObject(old_bmp);
   ReleaseDC(&memdc);
   ReleaseDC(dc);
Post by Pep » Thu Apr 14, 2005 8:36 pm
I've tried to reproduce the problem here using the Draw() method, but it does not give me any error using the latest v7.03. Which TeeChart Pro version are you using ? Also, could you please post an example into the news://steema.net/steema.public.attachments newsgroup with which I can reproduce the problem "as is" here ?
TMECHAM
Post by TMECHAM » Thu Apr 21, 2005 8:31 pm
Hi Josep,
I am using the latest version. I have sent a project to the attachments group per your request. It is a dialog app that loads a .tee file. All you have to do is resize the dialog to see the exceptions.
GL
Post by Narcís » Fri Apr 22, 2005 3:05 pm
Hi TMECHAM,
I've tested the application you sent and it works fine here for me.
Which Visual C++, operating system, graphic card, ... are you using? Can you run this application in another machine to see if it works there?
TMECHAM
Post by TMECHAM » Fri Apr 22, 2005 4:23 pm
I have reproduced it on both of my development machines:
PC#1 - WinXP SP2, VC++.Net 2003, NVIDIA GeForce FX 5200
PC #2 - W2K SP4, VC++.Net 2002, Matrox G450 DualHead
I see the exceptions on load about 1 in 4.
When I resize the dialog I see them every repaint event.
I'm catching the exceptions and just dumping them out to the debug console ...
First-chance exception at 0x7c81eb33 in tchart_test.exe: Microsoft C++ exception: COleDispatchException @ 0x0012ee78.
CTchart1::draw() catch(COleDispatchException)
First-chance exception at 0x7c81eb33 in tchart_test.exe: 0x0EEDFADE: 0xeedfade.
TMECHAM
Post by TMECHAM » Fri May 20, 2005 7:25 pm
I'm still seeing this with the latest version. Is there anything else I can do to help squash this bug?
Post by Pep » Mon May 23, 2005 10:05 am
I've been reviewing the sample you sent us, and I think it's not a problem related with the Chart, if you comment the following line :
the_chart.ShowWindow(SW_HIDE);
it works fine. I think the problem is related on how you're creating the bmp.
TMECHAM
Post by TMECHAM » Tue May 24, 2005 3:30 pm
I've resubmitted another project to the attachments group. I have simplified my code so that the problem should be easier to see. I have created 2 windows, one that has the chart and another that calls the Draw method of the chart. I am drawing into the same DC that gets passed into the Draw method and my draw code always works, so I know the DC and Bitmap associated with it are valid. The question is why is the chart throwing an exception from the Draw method a majority of the time?
With my old example, when you comment out the ShowWindow(SW_HIDE) code, the draw code that generated the exception was never being called because the paint rect was 0.
I hope this new code will help.
Tyler
