access violation
michel
access violation
Post by michel » Sun Jan 04, 2004 5:50 pm
When I try to close the form that contain a chart (instruction : unload me), I get: "Access Violation at address 504B766B in module
'TeeChart6.ocx'. Read of address FFFFFFFF"
The OS is Windows Me. The sofware is VB6 SP5.
Post by Christopher » Mon Jan 05, 2004 8:46 am
Hi --
I'm having trouble reproducing this one here I'm afraid. Would you be so kind as to send me some example code which I can run "as-is" to repeat this error here?
Many thanks.
Thank you!
http://groups.google.com
http://codenewsfast.com/
michel
Post by michel » Wed Jan 07, 2004 3:36 pm
I created a form (name : frmGraphes, properties :Windowstate :2 (maximized), no titlebar) on which I placed a TChart control (properties :TChart1.Width = frmGraphes.Width,TChart1.Height = frmGraphes.Height)
In order to leave the window frmGraphes, I detected the displacment of the mouse in the event :
Private Sub Form_MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
Static Xlast, Ylast
Dim Xnow As Single
Dim Ynow As Single
On Error Resume Next
'obtenir la position courante
Xnow = X
Ynow = Y
'Au premier mouvement, enregistrer simplement la position
If Xlast = 0 And Ylast = 0 Then
Xlast = Xnow
Ylast = Ynow
Exit Sub
End If
'Quitter seulement si la souris change effectivement de position
If Xnow <> Xlast Or Ynow <> Ylast Then
Db.Close
Unload frmGraphes
End If
All is OK until the instruction "unload frmGraphes" which produces the error message
Post by Pep » Wed Jan 07, 2004 4:35 pm
Hi Michel,
I've sent one example to the steema.public.attachments newsgroup which works fine here using the latest TeeChart Pro v6.04. Could you please test and modify (if required) it so I can reproduce the problem "as is" here ?
Josep Lluis Jorge
http://support.steema.com
