Problem with TeeEditor in 64 bit app
PetexUser
Post by PetexUser » Tue Jul 16, 2019 1:51 pm
We are using the TeeChart Pro v2018 ActiveX Control in our C++ applications
We provide access to the chart properties using the TeeEditor tool ( via a form button)
Initialise:
m_TeeEditor.SetChartLink(m_pChart->GetChartLink());
Show TeeChart properties Button response:
m_pChart->TeeEditorShowEditor();
We notice that GetChartLink returns a LONG and not a DWORD.
In 64 bit where high memory is addressed GetChartLink() returns a negative value.
The result is the TeeEditor cannot be displayed.
I can also see many similar tool methods return a LONG instead of a DWORD .
Is this an issue Steema is aware of ?
I look forward to your response
kind regards
Mark
Re: Problem with TeeEditor in 64 bit app
Post by Pep » Mon Jul 22, 2019 7:32 am
Hello Marc,
for 64 bit you have to use :
m_TeeEditor.SetChartLink64(m_pChart->GetChartLink64());
PetexUser
Post by PetexUser » Mon Jul 22, 2019 12:56 pm
Hi Pep,
Thank you for you support.
I somehow missed the x64 API calls.
Everything works fine now.
kindest regards
Mark
