ADO Database access - PROBLEM
Posted: Fri Dec 17, 2004 1:07 pm
hello,
I've tried to collect data from SQL Server 2000 and add the data directly to chart. I use ASP pages and ActiveX TeeChart version 6.0.0.5. The basic data fetch is as follows:
dim MyChart : set MyChart = Server.CreateObject("TeeChart.TChart")
dim data : set data = Server.CreateObject("ADODB.Connection")
dim record : set record = Server.CreateObject("ADODB.RecordSet")
data.open "DSN=xxx;Database=yyy;UID=uname;PWD=pwd", "", ""
for i=0 to Session("NoCircuits")-1
if circuit(i).plotI=1 then
strQuery="SELECT DateTime, OutValue FROM tblData WHERE CircuitNo=" & i & " AND Type='I' AND CaseID=" & Session("CaseID") & " AND MONTH(DateTime)=6 AND YEAR(DateTime)=YEAR(GETDATE())"
record.open strQuery,data,3,3
response.write record.RecordCount & "<br>"
MyChart.AddSeries(6)
MyChart.Series(seriesIndex).DataSource = Record
MyChart.Series(seriesIndex).YValues.ValueSource = "OutValue"
MyChart.Series(seriesIndex).LabelsSource = "DateTime"
MyChart.Series(seriesIndex).CheckDataSource
MyChart.Series(newSeries).VerticalAxisCustom = axCurrent
end if
next
In the example above I fetch current data for various circuits, and if the client has selected the current to be plotted (=circuit(x).plotI=1). I fetch the data from the database, and get 19 records (for example).
How can I set the data to Series0 (and further data to Series1, Series2, etc.)? When I load the page, the graph is empty. I need full example codes of how to do this.
I've tried to search the tutorials and manuals etc. but I cannot seem to add data to any series directly from database....
Thanks for any advises.
mike turner
end if
next
mike turner
