Problem with Monitor 4K
PhG47
Post by PhG47 » Thu Apr 06, 2017 6:33 am
It is impossible to resize a control "TeeChart on 2017 Pro ActiveX" by code if the size in [Twips] of the screen is bigger than a single integer. Integer long is required.
TChart.Width
TChart.Height
You can correct this problem
Philippe
PhG47
Re: Problem with Monitor 4K
Post by PhG47 » Fri Apr 07, 2017 5:45 am
Detailed testing...
TChart.Width
TChart.Height
The maximal value accepted is 31450, is too small for a monitor 4K...
Best regards
Philippe
Post by Yeray » Mon Apr 10, 2017 10:24 am
TChart ActiveX is a wrapper from TeeChart VCL; TChart inherits TControl, that declares Width as an Integer. So I'm not sure there's much we can do here.
http://docwiki.embarcadero.com/Librarie ... trol.Width
PhG47
Post by PhG47 » Mon Apr 10, 2017 11:38 am
Thank you for this information. I had an identical problem with the function native of sizing and moving of a form Access. The function "DoCmd.MoveWindow" is limited to values "Integer". But it is the bug of Access that I was able to by-pass with the API... Here is the same constructed function directly with the API. TControl is certainly not updated for a very long time...
Sub FormMoveWindow(vobForm As Form, Optional vloLeft As Long = -1, Optional vloTop As Long = -1, Optional vloWidth As Long = -1, Optional vloHeight As Long = -1)
' Remplace Access DoCmd.MoveWindow
' en Pixels
    Dim rectForm As RECT
    Dim vloL As Long
    Dim vloT As Long
    Dim vloW As Long
    Dim vloH As Long
    If Not ((vloLeft = -1) And (vloTop = -1) And (vloWidth = -1) And (vloHeight = -1)) Then
        ' Récupérer le rectangle de la fenêtre du controle
        GetWindowRect vobForm.hwnd, rectForm
        ' Adapter les valeurs
        If vloLeft = -1 Then
            vloL = rectForm.Left
        Else
            vloL = vloLeft
        End If
        If vloTop = -1 Then
            vloT = rectForm.Top
        Else
            vloT = vloTop
        End If
        If vloWidth = -1 Then
            vloW = rectForm.Right - rectForm.Left
        Else
            vloW = vloWidth
        End If
        If vloHeight = -1 Then
            vloH = rectForm.Bottom - rectForm.Top
        Else
            vloH = vloHeight
        End If
        ' Repositionner et redimentionner le formulaire
        MoveWindow vobForm.hwnd, vloL, vloT, vloW, vloH, True
    End If
If you corrected the bug "Access Anchor Control", I do not maybe need any more to use these properties. But for a monitor 4K, it is not correct.
Thank you very match
Best regards
Philippe
