Teechart 7 -> Teechart 2015 Performance degradation
mch
Post by mch » Fri Oct 09, 2015 10:13 pm
Our software worked perfectly with TeeChart 7 when plotting in real-time. Since we've upgraded to TeeChart 2015, we have serious performance issue. CPU usage it's up to the roof.
We're using fastline series, set auto paint to true/false to disabled drawing when adding points, etc...
Anyone is experiencing the same problem? Thx
Re: Teechart 7 -> Teechart 2015 Performance degradation
Post by Yeray » Tue Oct 13, 2015 8:00 am
Note TeeChart 2013.09 moved the default Canvas from GDI to GDIPlus. You can make sure to be using GDI to check if this affects the performance on your application.
Take a look at the options you have to change from GDIPlus to GDI here.
