Igor
- Newbie
Post
by Igor » Tue Nov 25, 2014 3:15 pm
I've got a problem while trying to apply function (one-value-function, like tfCorrelation) on my serie. Right after plotting it looks like this:
But after starting to drag graph with right mouse button right axis looks like this:
Then if I do unzoom movement (left click from bottom-right to up-left) it returns to state on first image.
Thanks in advance
Igor on Wed Nov 26, 2014 7:42 am, edited 1 time in total.
Post
by Yeray » Tue Nov 25, 2014 3:46 pm
I can't see the images you tried to add on your post. Could you please try to correct them?
Also, we'll probably need a simple example project we can run as-is to reproduce the problem here.
Igor
- Newbie
Post
by Igor » Wed Nov 26, 2014 8:26 am
Hello, I've edited first post. If you can't reproduce the problem, I'll upload example later.
Post
by Yeray » Thu Nov 27, 2014 8:16 am
Hello Igor,
Are you linking the different series to different vertical axes?
Igor
- Newbie
Post
by Igor » Thu Nov 27, 2014 9:04 am
Of course I'm linking different series to different vertical axes. They have different scales, so on one axis they will not be observable. Simple example in attachment, try to drag it.
- Correlation.zip
- (1.5 KiB) Downloaded 1724 times
Post
by Yeray » Thu Nov 27, 2014 9:53 am
Try hiding the right axis grid:
Chart1.axis.right.gridpen.visible = false;
Igor
- Newbie
Post
by Igor » Thu Nov 27, 2014 10:23 am
I've hidden grid, but there are still multiple "0.214" values on the axis and correlation line drops down when starting to drag.
Post
by Narcís » Thu Nov 27, 2014 3:37 pm
Hi Igor,
What about setting right axis increment, for example:
Chart1.axis.Right.Increment = 0.01;
Igor
- Newbie
Post
by Igor » Thu Nov 27, 2014 3:55 pm
Have you tried it on your side? When I set increment, I see no label at all at the right axis when starting dragging, and correlation line still drops down.
Post
by Yeray » Fri Nov 28, 2014 10:45 am
Igor wrote:Have you tried it on your side? When I set increment, I see no label at all at the right axis when starting dragging, and correlation line still drops down.
Try adding this at the end of your onLoadFunc. I can scroll the chart here always getting the "0.214" label on the right, with the latest TeeChart ActiveX version published, v2014.0.0.2.
Chart1.axis.Right.SetMinMax(lineF.YValues.Value(0)-1, lineF.YValues.Value(0)+1);
Chart1.axis.Right.gridpen.visible = false;
Chart1.Axis.Right.Labels.Clear();
Chart1.Axis.Right.Labels.Add(lineF.YValues.Value(0), lineF.YValues.Value(0).toFixed(3));
Igor
- Newbie
Post
by Igor » Fri Nov 28, 2014 2:08 pm
Thanks for response. Your code works but looks like dirty solution. If I apply more functions to this graph, I'll have to set new axis bounds each time which I didn't mean to do.
I think when right axis is set to automatic, it is not normal behaviour that I see now.
Post
by Yeray » Fri Nov 28, 2014 3:26 pm
Hello Igor,
Igor wrote:Thanks for response. Your code works but looks like dirty solution. If I apply more functions to this graph, I'll have to set new axis bounds each time which I didn't mean to do.
Note I suggested this trick because your right axis was in a quite particular situation: a single series assigned to the axis, with all its YValues being the same. This situation is internally handled showing a unique label in the middle of the axis.
If you add more series to the right axis, you shouldn't need such a trick and you can set it to be automatic again.
Igor
- Newbie
Post
by Igor » Fri Nov 28, 2014 3:57 pm
Is it normal that I need a trick at all in that situation? Why doesn't it just work?
