Determine if custom axis is visible.
Posted: Fri Oct 17, 2014 1:53 pm
by 13052810
I'm using TeeChart Pro v2013.0.1.4.131120
Using FastLine.
When a series is assigned to a custom vertical axis, the axis will only be visible if the series is active. This also applies to assigning multiple series to a single axis.
When there is no active series, the axis becomes invisible.
How can I detect when the custom axis turns invisible?
I have tried this:
TChart1.Axis.Custom(0).Visible
This does not change when a "no active series" condition causes the axis to become invisible.
Re: Determine if custom axis is visible.
Posted: Fri Oct 17, 2014 2:33 pm
by narcis
Hi tirby,
You can do it manually like this:
Private Sub Form_Load()
    List1.Clear
    TeeCommander1.ChartLink = TChart1.ChartLink
    TChart1.Aspect.View3D = False
    TChart1.Legend.CheckBoxes = True
    Dim CustomAxis As Integer
    CustomAxis = TChart1.Axis.AddCustom(False)
    For i = 0 To 5
        TChart1.AddSeries scLine
        TChart1.Series(i).FillSampleValues
        If i Mod 2 = 0 Then
            TChart1.Series(i).VerticalAxisCustom = CustomAxis
        End If
    Next
    TChart1.Axis.Left.EndPosition = 50
    TChart1.Axis.Custom(CustomAxis).StartPosition = 50
Private Sub TChart1_OnClickLegend(ByVal Button As TeeChart.EMouseButton, ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
    For i = 0 To TChart1.Axis.CustomCount - 1
        Dim AxisVisible As Boolean
        AxisVisible = False
        For j = 0 To TChart1.SeriesCount - 1
            If ((TChart1.Series(j).VerticalAxisCustom = i) And (TChart1.Series(j).Active)) Then
                AxisVisible = True
            End If
        Next
        Dim text As String
        If AxisVisible Then
            text = "Custom Axis " & CStr(i) & " is VISIBLE"
        Else
            text = "Custom Axis " & CStr(i) & " is NOT visible"
        End If
        List1.AddItem text
    Next
