return value loadfromfile()
Posted: Sun Sep 07, 2014 3:12 pm
by 16668787
Using the latest AX version.
I'm using the import method loadfromfile() and want to check if the loading went without problems. Looking via the debugger it shows that this method always returns NIL no matter if the was loaded successfully, wasn't found, was corrupt etc..
Shouldn't there be a return value like a Boolean or a pointer (like normal filehandling) to check this.
TIA,
Jack
Re: return value loadfromfile()
Posted: Mon Sep 08, 2014 12:10 pm
Posted: Tue Apr 21, 2015 5:42 pm
by 16671577
I posted this request some time ago.
In the tracker I see that at first:
Status CONFIRMED RESOLVED
but some time later:
Resolution --- WONTFIX
Does this means it won't get changed (AX2015 gives no returnvalue)? Why?
TIA,
Jack
Posted: Wed Apr 22, 2015 7:36 am
Hello Jack,
Jack007 wrote:I posted this request some time ago.
At the same time, not later.
First of all note TeeChart ActiveX is a wrapper from TeeChart VCL so some issues in the ActiveX version depend on the VCL version.
That's why I created both a VCL and an ActiveX ticket,
B911 and
B912 on 2014-09-08 with a "Blocks"/"Depends on" relation between them.
David closed
B911 on 2014-09-12 setting "Status" field to "Resolved" and "Resolution" field to "Won't Fix", both fields at the same time. He also wrote a comment explaining the reason:
david wrote:Returning a Boolean will not indicate the exact cause.
Correct behaviour is to raise an exception, being the exception class and properties the info about the problem.
See for example Classes.pas TStrings LoadFromFile:
procedure TStrings.LoadFromFile(const FileName: string);
var
Stream: TStream;
Stream := TFileStream.Create(FileName, fmOpenRead or fmShareDenyWrite);
try
LoadFromStream(Stream);
finally
Stream.Free;
OurTTeeSeriesSourceFile.LoadFromFile, TImportChart.LoadFromFile and TeeStore.pas unit LoadChartFromFile, all use the RTL default TFileStream classes.
A custom function can always "eat" the exception and return a boolean, if desired:
uses
TeeStore;
function Load(const AChart:TCustomChart; const AFile:String):Boolean;
try
LoadChartFromFile(AChart,AFile);
result:=True;
except
on Exception do
// EAT
result:=False;
if Load(Chart1,'test.tee') then
Caption:='OK'
Caption:='BAD';
However, this is not recommended. Exceptions must surface-up to callers.
Jack007 wrote:Does this means it won't get changed (AX2015 gives no returnvalue)? Why?
I'm afraid yes. And the reason is the one David explained there and I copied above.
Of course don't hesitate to let us know if you find it's not accurate enough or if it doesn't fit your needs.
