Issue related to Color Grid Series.
amol
Post by amol » Thu Dec 19, 2013 11:38 am
I am facing an issue on ActiveX-7, where I am using the color grid series to plot my data.
I was looking for a solution in the T-Chart editor, where both my problems are resolved, but was not able to find.
I am attaching a doc which contains the detailed scenario of the issue. Please suggest any work-around so as to handle this issue asap.
Hardeep
Issue related to color grid series.rar
(123.51 KiB) Downloaded 1074 times
Re: Issue related to Color Grid Series.
Post by Yeray » Fri Dec 20, 2013 3:35 pm
Hi Hardeep,
Could you please try if the actual version (eval) still reproduces the issue for you?
If so, could you please arrange a simple example project we can run as-is to reproduce the problem here? As simple as possible, with as less cells as possible, but still reproducing the issue.
