Default color palette in TeeChart ActiveX 2013
lietmeyer
Post by lietmeyer » Mon Aug 26, 2013 10:05 am
I have just migrated from ActiveX version 7 to the new ActiveX 2013. In version 7, there used to be a color palette value cpDefault (=10). If this was set, the color belonging to the selected theme was displayed. By contrast, cpTeeChart (=0) set the colors to the standard TeeChart colors, overriding any color values dictated by the selected theme. In version 2013, cpTeeChart (=0) still exists and works as it used to, but I can't find any equivalent to cpDefault. In the examples, there appears to be a value that produces the behaviour of the old value cpDefault (=10), but I can't find any value listed in the supplied TeeChartDefines.h file that achieves this effect. What is the numeric value associated with a "default" color palette, i.e. a neutral palette that allows the palette belonging to the chosen theme to be applied?
Re: Default color palette in TeeChart ActiveX 2013
Post by Yeray » Wed Aug 28, 2013 2:37 pm
Right, the cpDefault palette doesn't exist any more. I've added it to the defect list to be revised for further releases (TA05016698).
