Dear Support
I have newbie like question:
Uppon adding a simple array to the chart with the AddArray method, i get the following error message:
"Variant or safe array index out of bounds"
The following simple VB code wo'nt work:
Dim X_ARRAY(10) As Single
Dim Y_ARRAY(10) As Single
Dim I As Integer
Randomize
For I = 1 To 10
X_ARRAY(I) = CSng(I)
Y_ARRAY(I) = Rnd * 10#
Debug.Print I, Y_ARRAY(I)
Next I
' Now add it to the chart.
frmAddArray.TChart1.AddSeries scLine
frmAddArray.TChart1.Series(0).AddArray UBound(Y_ARRAY), Y_ARRAY(), X_ARRAY()
What can be the problem?
Tx in advance, regards
Andras
AddArray problem
Hi Andras,
which TeeChart Pro version are you using ? I've just test it here using the v7.02 with VB6 and works fine.
Pep Jorge
http://support.steema.com
Hi Andras,
it also works fine using the v6.05 downloadable from our web site (at the private customers download page).
If you still having problems I can post an example into the steema.public.atachments newsgroup so you can test it.
Pep Jorge
