[CLOSED] arrows and text at the top of a chart
Posted: Tue Apr 09, 2013 9:10 am
by 16665441
TeeChart Pro v20120.0.9.120901
windows 8
is it possible to draw arrows with text at the top of the chart (see attachment)
the arrows en text must scroll horizontaly with chart
arrows should not scroll vertically if the chart scroll verticallypoints in the chart are drawn in real time, a point every 30 seconds
Is it possible to delete the first "POINTER" each part of "scline" (see attachment °
thks
Re: arrows and text at the top of a chart
Posted: Tue Apr 09, 2013 3:14 pm
Let me start from the second part:
jika wrote:Is it possible to delete the first "POINTER" each part of "scline" (see attachment °
This can be achieved using the OnGetPointerStyle. Of course you have to know the index of both the SeriesIndex and the ValueIndex to hide, or how to calculate them:
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scLine
  TChart1.Series(0).FillSampleValues 10
  TChart1.Series(0).asLine.Pointer.Visible = True
  TChart1.Series(0).SetNull 5
Private Sub TChart1_OnGetSeriesPointerStyle(ByVal SeriesIndex As Long, ByVal ValueIndex As Long, AStyle As TeeChart.EPointerStyle)
  If SeriesIndex = 0 Then
    If ValueIndex = 0 Or ValueIndex = 6 Then
      AStyle = psNothing
    Else
      AStyle = psDownTriangle
    End If
  End If
jika wrote:is it possible to draw arrows with text at the top of the chart (see attachment)
This is a bit more tricky. I'd draw both the arrows and the texts manually. Here it is an example:
  TChart1.Header.Visible = False
  TChart1.Walls.Visible = False
  TChart1.Series(0).FillSampleValues 25
  Dim i As Integer
  For i = 0 To TChart1.Series(0).Count - 1
    If (i Mod 8 = 0) Then
      TChart1.Series(0).SetNull i
    End If
  Next i
Private Sub TChart1_OnGetSeriesPointerStyle(ByVal SeriesIndex As Long, ByVal valueIndex As Long, AStyle As TeeChart.EPointerStyle)
    If ((valueIndex - 1) Mod 8 = 0) Then
      AStyle = psNothing
    Else
    End If
  End If
  Dim valueIndex As Integer
  Dim startXPos, YPos As Integer
  Dim textXPos As Integer
  Dim textString As String
  YPos = TChart1.GetChartRect.Top
  With TChart1.Series(0)
    valueIndex = .FirstValueIndex
    startXPos = -1
    Do While valueIndex <= .LastValueIndex
      If valueIndex > 0 And .IsNull(valueIndex - 1) Then
        startXPos = .CalcXPos(valueIndex)
        TChart1.Canvas.Pen.Color = .Color
        TChart1.Canvas.Pen.Width = 2
        TChart1.Canvas.DrawLine startXPos, YPos, startXPos + 5, YPos - 5
        TChart1.Canvas.DrawLine startXPos, YPos, startXPos + 5, YPos + 5
      End If
      If valueIndex < .Count - 1 And .IsNull(valueIndex + 1) Then
        If startXPos = -1 Then
          TChart1.Canvas.DrawLine TChart1.GetChartRect.Left, YPos, .CalcXPos(valueIndex), YPos
          TChart1.Canvas.DrawLine .CalcXPos(valueIndex), YPos, .CalcXPos(valueIndex) - 5, YPos - 5
          TChart1.Canvas.DrawLine .CalcXPos(valueIndex), YPos, .CalcXPos(valueIndex) - 5, YPos + 5
          textString = "Some text"
          textXPos = (TChart1.GetChartRect.Left + (.CalcXPos(valueIndex) - TChart1.GetChartRect.Left) / 2) - TChart1.Canvas.TextWidth(textString) / 2
          TChart1.Canvas.TextOut textXPos, YPos - 15, textString
        Else
          TChart1.Canvas.DrawLine startXPos, YPos, .CalcXPos(valueIndex), YPos
          textXPos = (startXPos + (.CalcXPos(valueIndex) - startXPos) / 2) - TChart1.Canvas.TextWidth(textString) / 2
        End If
        startXPos = -1
      Else
        If valueIndex = .LastValueIndex Then
          If startXPos > -1 Then
            TChart1.Canvas.DrawLine startXPos, YPos, TChart1.GetChartRect.Right, YPos
            textXPos = (startXPos + (TChart1.GetChartRect.Right - startXPos) / 2) - TChart1.Canvas.TextWidth(textString) / 2
          End If
        End If
      End If
      valueIndex = valueIndex + 1
    Loop
  End With
