Two programs with different teechart releases on same PC
isc01
Post by isc01 » Thu Sep 30, 2004 2:50 am
I have two application with teechart pro included:
application A (I am the developer) with 5.0.6.1 teechartLang.ocx
application B (I dont know the developer) with 5.0.3.1 teechart.ocx
installing first A then B and reregistring 5.0.3.1 teechart.ocx B is running and A crashes
installing first B then A, A is running and B crashes
what I can do?
Post by Pep » Thu Sep 30, 2004 6:24 am
have you tried to :
- install B and A but just register the v5.0.6.1 ? It should work in this manner.
isc01
Post by isc01 » Sun Oct 03, 2004 5:00 am
Yes,
I did this as first but with 5.0.6.1 only A works
register v 5.0.3.1 then only B works
Post by Christopher » Thu Oct 07, 2004 4:37 pm
Hi ..
Yes, I did this as first but with 5.0.6.1 only A works
Where is the app crashing? Are you sure you're not using a method/property available in the teechartlang.ocx but not in the teechart.ocx?
Thank you!
http://groups.google.com
http://codenewsfast.com/
