show trend on a zoomed area
aligator32
Post by aligator32 » Thu Aug 23, 2012 7:56 am
Hi, how it is possible to show a trend line on a zoomed area ? the trend stays allways on the full serial , is this possible to fix the first element and the last to include in the calculation of the trend?
regards
JP
Re: show trend on a zoomed area
Post by Yeray » Thu Aug 23, 2012 10:08 am
You could populate a dummy series with only the visible values at OnZoom event, and show the Trend of this dummy series.
Ie:
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scBar
  TChart1.Series(0).Name = "Source"
  TChart1.Series(0).FillSampleValues 50
  TChart1.Series(1).Name = "Dummy"
  TChart1.Series(1).ShowInEditor = False
  TChart1.Series(1).ShowInLegend = False
  TChart1.Series(1).Active = False
  TChart1.AddSeries scLine
  TChart1.Series(2).Name = "Trend"
  TChart1.Series(2).SetFunction tfTrend
  TChart1.Series(2).DataSource = TChart1.Series(1)
Private Sub TChart1_OnZoom()
  TChart1.Series(1).Clear
  Dim i As Integer
  For i = TChart1.Series(0).FirstValueIndex To TChart1.Series(0).LastValueIndex
    TChart1.Series(1).AddXY TChart1.Series(0).XValues.Value(i), TChart1.Series(0).YValues.Value(i), "", clTeeColor
  Next i
  TChart1.Series(2).CheckDataSource
If you want to get the Trend line of all the values when you zoom out, you could use the OnUndoZoom for it. Then you could use the source series with the trend function:
Private Sub TChart1_OnUndoZoom()
  TChart1.Series(2).DataSource = TChart1.Series(0)
aligator32
Post by aligator32 » Thu Aug 23, 2012 1:07 pm
Thanks a lot, I did it, it's fine...
regards
JP
