Legend behaviour
JKO
Legend behaviour
Post by JKO » Tue Mar 27, 2012 5:14 pm
Normally I'm using the legend in it's default behaviour. In this case the chart is narrowed to accomodate the legend position. Recently I changed this behaviour to legend.resizechart=false.
By doing this the legend is drawn in the area of the charts (which is what i wanted) but also behind the components of the chart, like the grid, the series, axis etc.. Why is this? This isn't logical.
To bring the legend to the front i've got to set the position to custom and set its position.
Why is the z-order of the legend different when setting the position to custom?
Greetings,
Jack
Re: Legend behaviour
Post by Yeray » Wed Mar 28, 2012 2:01 pm
Hi Jack,
Right, I also think resizechart=false should draw the legend above the chart. I've added it to the wish list to be investigated for future releases (TV52016112).
In the meanwhile you could use CustomPosition=true instead.
