No context-sensitive help installed
Primi
Post by Primi » Wed Mar 07, 2012 8:00 am
I've installed v2011 of ActiveX and from 'Editing' dialog box, if you press on the button 'Help', it's shown the message "No context-sensitive help installed". In the Windows registry there appear correctly the entries explained in the chapter 18 of the tutorial (TeeUserx2011.hlp). Could you help me?
Primi.
Re: No context-sensitive help installed
Post by Narcís » Wed Mar 07, 2012 3:16 pm
Hi Primi,
In which development environment does this occur? Which operating system are you using?
Primi
Post by Primi » Wed Mar 07, 2012 3:33 pm
Hi Narcís,
OS Windows XP Professional SP3
Environment: VB6
Best regards,
Primi
Post by Yeray » Fri Mar 09, 2012 4:36 pm
Hi Primi,
Is your OS 64bit or 32bit?
Primi
Post by Primi » Fri Mar 09, 2012 4:56 pm
My OS is 32bit.
Post by Yeray » Thu Mar 15, 2012 10:18 am
Hola,
Excuse us for the delayed reply.
We've just fixed it so it should work fine with the next maintenance release that we expect to be published before the end of this month.
However, if you are in a hurry, just tell us and we'll send you an ocx compiled with the actual sources.
