export excel
Posted: Tue Sep 14, 2004 11:09 am
by 9082638
Is it possible to export the data in the EXCEL sheet with the legend (not only X,Y) ?
Does someone have already encounter this demand?
Stefano
Posted: Tue Sep 14, 2004 2:14 pm
by Pep
Hi Stefano,
I'm not sure what you refer saying "with the legend", could you please be more specific ?
Posted: Fri Sep 17, 2004 4:10 pm
by 9082638
Hi Pep,
If the name of one Series is "Temperature",
when I export the data in excel I would like that in the title of the column there is " Temperature " and not "Y"
Posted: Mon Sep 20, 2004 5:26 pm
by Pep
this feature is not yet available, but will be included in the next maintenance release (which will be out in 4-5 weeks more or less).
You will be able to change the X and YValues.Name which will be the text that will appear in the xls file.
Sample Code :
Private Sub Command1_Click()
With TChart1.Export.asXLS
.IncludeHeader = True
.IncludeLabels = True
.SaveToFile "c:\Test.xls"
End With
Private Sub Form_Load()
With TChart1
.AddSeries scPoint
.Series(0).FillSampleValues (5)
.Series(0).YValues.Name = "YVal"
End With
Posted: Wed Nov 24, 2004 4:20 pm
by 9524255
Hi!
Is this feature now available? our customers really want it
Posted: Wed Nov 24, 2004 4:37 pm
by Pep
it has been implemented. It will be ready for the next maintenance release which will be out very soon.
Posted: Thu Nov 25, 2004 11:13 am
by 9524255
hi
and what about the same feature in ChartGrid? it will also show
XValues.Name and YValues.Name instead of Text and Y?
Posted: Thu Nov 25, 2004 2:29 pm
by Pep
yes, changing it as above will also take effect in the ChartGrid.
Posted: Fri Dec 17, 2004 1:08 pm
by 9524255
hi
so what about release with this feature implemented?
Posted: Mon Dec 20, 2004 10:37 am
by Pep
Hi Repka,
the new maintenance release will be posted on our web site this week, if you need urgently plese contact with me directly to
pep@steema.com.
Posted: Thu Dec 23, 2004 6:37 pm
by 9524255
hi!
i have downloaded and installed new release.
i thought property Name should work in the same way for XValues and YValues. but it is not so.
for example i do :
.Series(NewSeriesNo).XValues.Name="Week"
.Series(NewSeriesNo).YValues.Name="Demand"
then i export series to Excell ( or view data with ChartGrid). the name of Xvalues of series in the header is still 'Text'. but i want to see
.Series(NewSeriesNo).XValues.Name there.
is there the way to obtain the result i desire?
Posted: Fri Dec 24, 2004 1:44 pm
by Pep
for the moment you can specify a text for the X and YValues, as in the following example :
With TChart1
.Aspect.View3D = False
.AddSeries scLine
For i = 2 To 20
.Series(0).AddXY i, Rnd * 100, "aaa", clTeeColor
Next i
.Series(0).XValues.Name = "XValues"
.Series(0).YValues.Name = "YValues"
End With
ChartGrid1.Chart = TChart1
With ChartGrid1
.ShowLabels = False
.ShowColors = False
End With
The text for the labels cannot be changed, we'll add one more property to be able to change it for the next maintenance release.
