Question about Percentage
Cliven
Post by Cliven » Mon Sep 13, 2004 7:59 am
I encounter a problem about te percentage.
if the data value is equal to 0, theteechart's pecentage will show 100% but not 0%.
For example, there is Food and Drink dimension, and there is 2 state :USA and Canada. For USA, Food and Drink value also equals to 0, according to the teechart, value 0 is same as 100%, then
100% + 100% = 200% ,this is not the correct answer.
p/s: i would like to post the image about this problem so that it is more easy to understand, may i know how to do this.
Thank You.
Post by Pep » Mon Sep 13, 2004 1:07 pm
yes, you're correct. I see the problem. I've added it on our defect/wish list and a fix for it will be considered to inclusion for the next release. In meantime a workaround is to set the Mark text in the OnGetMarkText event.
