Cannot resize control. Control goes blank.
ronm
Post by ronm » Fri Oct 07, 2011 10:10 pm
I am having difficulty sizing my charts. The chart seems to have a display size that it uses regardless of what size I set the control to. Also, when I resize the chart, it will sometimes not display at all, and I cannot figure out a way to get the chart to display again. What am I doing wrong? It seems to work in your Access example. In fact, that is currently what I am doing. I size the chart in your demo and copy it into my project. If I then try to modify the size farther, it fails.
Brad
TeeChart.zip
Chart now fails to display entirely
(95.02 KiB) Downloaded 656 times
Re: Cannot resize control. Control goes blank.
Post by Sandra » Mon Oct 10, 2011 1:20 pm
Hello Brad,
I can reproduce your problem using your project, but when I have modified your project, changing the control of Activex8 you have added for my control Activex8, seems that problems is solved and chart appears. Please, can you try if next project works as you expected and your problem is solved?
TeeChart2.zip
(146.33 KiB) Downloaded 683 times
I hope will helps,
ronm
Post by ronm » Wed Oct 12, 2011 5:24 pm
Sandra wrote:I can reproduce your problem using your project, but when I have modified your project, changing the control of Activex8 you have added for my control Activex8, seems that problems is solved and chart appears. Please, can you try if next project works as you expected and your problem is solved?,
Hello Sandra,
Using your project, I am still able to replicate the problem.
Brad
Post by Sandra » Thu Oct 13, 2011 1:51 pm
Hello Brad,
We are working to try to find a solution for this problem and we have inform you asap.
Post by Sandra » Fri Oct 14, 2011 2:16 pm
Hello Brad,
Please, take a look in my replay in thread and check again if your problem appears using new OCX.
