Zoom on null values
Posted: Mon Dec 06, 2010 10:43 am
by 15054354
I have a problem while zooming on area with null Values. Hereafter you can see all my charted values
- allvalues.png (6.5 KiB) Viewed 7352 times
Before Zoom:
- beforeZoom.png (33.02 KiB) Viewed 7353 times
After zoom on 18/11/10 -> 28/11/10 area
- afterZoom.png (28.69 KiB) Viewed 7362 times
At the beginning (before zoom) the slope of the curve between 09/11/10: 46.11 and 22/11/10: 51.668 seems normal.
Just after zoom the slope changes significantly (between 18/11/10 -> 22/11/10) , because it links the value 0 of 18/11/10 with value 51.668 at 22/11/10.
I would like to have the same slope as the one between 09/11/10 and 22/11/10, because all values between these two dates are Null values ( added with ADDNULLXY function), and so 18/11/10 value of 0 should not be taken into account.
How should I proceed?
Petar
Re: Zoom on null values
Posted: Tue Dec 07, 2010 12:08 pm
by narcis
Hi Petar,
I see your bottom axis is zoomed but not your left axis. Do you only have horizontal zoom enabled? Code snippet below doesn't produce such a chart for me here. If I zoom around 18th November I don't get the first segment painted:
- ZoomNulls.jpg (56.14 KiB) Viewed 7340 times
Is this what you expected? Which TeeChart version are you using? Could you please modify code snippet below so that we can reproduce the problem here?
Private Sub Form_Load()
TChart1.Aspect.View3D = False
TChart1.Axis.Bottom.Labels.DateTimeFormat = "dd/mm/yy"
TChart1.AddSeries scLine
TChart1.Series(0).asLine.TreatNulls = tnSkip
TChart1.Series(0).XValues.DateTime = True
TChart1.Series(0).AddXY CDate("8 / 11 / 2010"), 46.494, "", clTeeColor
TChart1.Series(0).AddXY CDate("9 / 11 / 2010"), 46.11, "", clTeeColor
TChart1.Series(0).AddNullXY CDate("10 / 11 / 2010"), 0, ""
TChart1.Series(0).AddNullXY CDate("11 / 11 / 2010"), 0, ""
TChart1.Series(0).AddNullXY CDate("12 / 11 / 2010"), 0, ""
TChart1.Series(0).AddNullXY CDate("15 / 11 / 2010"), 0, ""
TChart1.Series(0).AddNullXY CDate("16 / 11 / 2010"), 0, ""
TChart1.Series(0).AddNullXY CDate("17 / 11 / 2010"), 0, ""
TChart1.Series(0).AddNullXY CDate("18 / 11 / 2010"), 0, ""
TChart1.Series(0).AddNullXY CDate("19 / 11 / 2010"), 0, ""
TChart1.Series(0).AddXY CDate("22 / 11 / 2010"), 51.668, "", clTeeColor
TChart1.Series(0).AddXY CDate("23 / 11 / 2010"), 50.363, "", clTeeColor
TChart1.Series(0).AddXY CDate("24 / 11 / 2010"), 51.2, "", clTeeColor
TChart1.Series(0).AddXY CDate("25 / 11 / 2010"), 50.25, "", clTeeColor
TChart1.Series(0).AddNullXY CDate("26 / 11 / 2010"), 0, ""
TChart1.Series(0).AddXY CDate("29 / 11 / 2010"), 52.15, "", clTeeColor
Posted: Tue Dec 07, 2010 2:07 pm
by 15054354
Hi Narcis,
I forgot to precise that I'm using fastlines. I'm using version 8 of TeeChart. You can check this code:
TChart1.AddSeries (scFastLine)
TChart1.Series(0).asFastLine.TreatNulls = tnSkip
Petar
Posted: Tue Dec 07, 2010 2:50 pm
by narcis
Hi Petar,
The only solution I can think of is adding more intermediate points as a smoothing function would:
TChart1.AddSeries scFastLine
TChart1.Series(1).SetFunction tfSmoothing
TChart1.Series(1).DataSource = TChart1.Series(0)
However, smoothing function ignores null values so you should add intermediate points to your data.
Posted: Tue Dec 07, 2010 3:05 pm
by 15054354
Thank you for the solution, I think that we'll rather use the last non-null value.
Petar
