Graph height issue
Posted: Tue Oct 05, 2010 9:19 am
by 9535061
We are using TeeChart Pro Activex Control v7 and also tested the functionality with TeeChart Pro v8 ActiveX evaluation version.
I am getting problem that when the series is continuously getting plotted the graph size increases momentarily and then reduces to normal.
YOu can view this in the following pictures,
I found an similar issue in TF02013500.
Is there any reason why is this happening. And could you suggest some solution or workaround for this?
INITIAL GRAPH
INCREASED SIZE
Thanks for your help,
Re: Graph height issue
Posted: Wed Oct 06, 2010 6:58 am
by 9535061
Please help me!!!
Posted: Wed Oct 06, 2010 10:00 am
by narcis
Hi roger,
